I am putting a new track on my 02 Viper and am wondering if I can put a 1.5" Ripsaw on it without it rubbing on anything, or is 1.25" the tallest I can safely go? I never plan on putting studs on the track but am highly consierding switching to an M-10 suspension in the near future... not sure if that would make any difference.
Thank you.
Thank you.
ViperXC
I removed the heat exchanger/tunnel protectors and went with 1.75 but if you leave those in, 1.25 is the biggest you can go.
I put on the 1.25 and you will need to trim the track or remove the exchanger protectors to keep it from rubbing. I removed the protecters since i don't plan on running studs. Aggressive riding on hard pack will rip the lugs off the 1.5 much easier than the 1.25. The 1.25 seems to work very well and should offer the most longevity.
