short to long track Q's
brndnrsm
Hospers, IA
I have a 02 viper that has 121 with extension to 144. I would like to get into the 151+ track. Can i just buy longer rails? or do I have to get a whole skid?
The current rails are also bent so no matter what I'll need new rails but the rest of the suspension is good. any help is greatly appreciated.
I would get a mtn skid, watch snowest, and you will find a decent skid for the cost of rails or less.
The Trail Skid Has A W Arm Vs. H Arm On The Mountain Skid. You Will Get Better Results By Replacing With A True Mountain Skid
W arm
The W arm and H arm are the same distances but you lose the front wheels with the W arm. With the H arm rails, you need lower centre shock brkt and lower L brackets the front arm W or H attaches to. You can't use a H arm where a W arm fits . Just to confuse you a little.
Thanks everyone I bought a 153 off a 08 nytro came with nice track extroverts and entire skid 400 for the whole works shipped but I'll try figure it out but any triucks you guys know of let me know still reading gild's post I'm confused without looking at it.
The shafts on the viper skid may swap out on the Nytro skid, so you have the correct length shafts, Don't worry about the w vs h arm as you have a complete skid, you need the mount points measured from the drive axle, and the extroverts will need to be pressed on the drive axle.
