yamaviperGS30
- Jan 10, 2004
I just installed a 9830 track and was wondering if you need to trim the luggs or the heat exchange protectors. The luggs go over where the clips run and hit the front protectors and I don't want to trimm the protectors since I'm studding. I also took the chaincase off and am wondering where the spacers go back on at. Does the large one go on bottom gear and small one on top and is their any small washers that go on[I can't seem to find any]. And do both spacers go behind the gears.
blueblooded
yamaviperGS30 said:I just installed a 9830 track and was wondering if you need to trim the luggs or the heat exchange protectors. The luggs go over where the clips run and hit the front protectors and I don't want to trimm the protectors since I'm studding. I also took the chaincase off and am wondering where the spacers go back on at. Does the large one go on bottom gear and small one on top and is their any small washers that go on[I can't seem to find any]. And do both spacers go behind the gears.
You dont need to trim anything,i installed the same track on my 01 srx and once you ride it it will wear itself in.As far as the spacers in the chaincase here is a link that will give you a diagram of how things go back together.
http://216.37.204.205/Yamaha_OEM/YamahaSnow.asp
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
you have to go there and type in the year of sled and then the type of sled and it will be under the catagory track drive 2.
yamaviperGS30
- Jan 10, 2004
Thanks guys, exactly what I needed.
blue magnaman
yu need a good manual my friend....will be yure best friend whan doing a project like that.
