vmax4ken
just sold my my vmax4 and bought a 1998 600 srx...just wondering if there was a way to check the cables on the valves with out taking them apart..
Not really
It really only takes a few minutes to pop them apart once you do it a couple times.
Idle the sled down to below 1000 RPM and pull the cover off the Power valve motor. The valves should be pulled into the high position putting the cables under tension. Push on the exposed section of each cable and if you create slack then that cable has broken or pulled through the valve if it stays taunt then it's O.K.. It's a quick check that takes less than a minute.
Always worked for me. Also been there and done it.
