how do i take out factory rivits in my clutch weights?im trying to tune my clutching do i grind the old ones out then hammer the new ones in?any help would be great
drill the rivet about 1/4" then use the knockometer and give them a beating with a punch. to put them back in slide em in and mushroom the top with the knockometer. check they don't rub in clutch and away you go.
take a grinder and grind the head off carefully. then take a punch and knock the remainder of the rivet out. put new rivet in and mushroom the non shouldered end over, so it can't come out.....finished....now go ride.
