So I pulled the chaincase and everything apart a few days ago to replace driveshaft bearings, and when reassembling I cannot figure out or remember for the life of me how or where these 2 collars/bushings came from. I think they go on the bottom shaft somewhere but I'm not really sure. I have looked at a diagram but its really hard to tell how it goes. Can anyone help?
Snowbear
I believe these are spacers that go behind the actual gear when yu are reasembling. one for the top and one for the bottom.
could be wrong but I just did mine and I had one on each spline.
If they are the ones that are the same basic size with the o-rings in them(which they look to be), on goes on the lower shaft behind the chaincase, and the other goes on the lower shaft behind the gear.
Snowbear
sending you an e-mail with the manual attached. you'll see as it has an exploded picture of the chaincase.
I know one of them doesn't go behind the lower gear because I have that one. These two are both the same sizes and are about 13mm wide/thick. They do however slide onto the lower shaft pretty easily so I think they may go on the lower in some configuration. Thanks for the manual Snowbear.
Spacers
I believe that one of them goes on the top shaft after the gear is on. (between the gear and bearing/cover)
Before installing the chain check the alignment with a metal ruler or a straight edge.
Good Luck!
Good Luck!
One goes behind the chaincase on the lower drive shaft but I cannot seem to find where the 2nd one goes by looking at the diagrams.
I think that they are the spacers that the seal runs on because they have the oring inside that seals them to the shaft. Are they both the same length? I just did my 98 sx and I am sure that they are the spacer the seal runs on.
