timl1978
The arrow on the top the piston means what? Does it mean that it should be pointed towards the front of the sled when installing?
Are there any other things I should keep in mind?
Use non synthetic oil
T up on ring install
arrow points to the exhaust port.
Check ring end gaps, Make sure they are on opposite side of piston.
timl1978
DV8 said:Check ring end gaps, Make sure they are on opposite side of piston.
don't the gaps go over the little knurles in the ring seat?
timl1978 said:don't the gaps go over the little knurles in the ring seat?
Yes they do..
What the hell may as well check ring end gap too wile your in there.
