tripplec
My sled is sluggish at the upper end. The RPM do get up to about 8k but top speed is below the sleds ability. I had feedback the the secondary clutch sheave spacing could be an insue (Large sheave contect to the chain case). The belt is slightly worn in my estimation. 3-4mm below the top of the sheave. I have a spare and it is the same width as what is on it. I got the sled this way and have not replace the belt. I haven't put many km on it myself about 1000km in two years. Bottom seem fine and reverse is too torquey (digs a hole and I get stuck) even with easy throttling. This had a fuel/temp management system for the carbs with Normal/Oxigen settings on a switch. Our gas has ethenol added and may be considered as oxigenated but . I can't say it makes it difference in my drive. I does seen to drink oil but I was told that won't slow it down.
I can see that the belt change appears complex and maybe a special tool is required and I hope to pickup and try a new belt this season.
Any help with the belt change process and/or what might be slowing it down would be helpful. I noticed some info that mutiply head gaskets were used. I can see only one(or it certain appears as one) below the cylinder top about 1/16th thick.
Thx
Thx
