Hey guys what is the best non abrasive sticker gunk out that you use, I need to clean the tunnel on my viper and some on the hood....
Nick
Nick
Well I re-research and found some answers, Googone Goof off (done it before and never again) WD40 is what I will try, Peanut butter (not sure I want my sled stinking like PB and 2 stroke oil....
Mods feel free to erase this one....
Nick
Nick
mineral spirits....works like a charm.
WD 40 is not doing it for me....Are you sure about the Mineral Spirits Daman...?
yes,,that's all i use for sticker residue like old trail permits or registration stickers,yep works good,Mineral Spirits is a weak cleaner will not hurt paint.Nicko said:WD 40 is not doing it for me....Are you sure about the Mineral Spirits Daman...?
Ok, I will try it...email me your address so I can send you the paint shop bill, incase I screw it up....LOL....Thanks Daman....
Found some odorless Mineral Spirits and did one side, looks great, Thanks.
No problem......: )Nicko said:Ok, I will try it...email me your address so I can send you the paint shop bill, incase I screw it up....LOL....Thanks Daman....
See..i wouldnt steer you wrong...Nicko said:Found some odorless Mineral Spirits and did one side, looks great, Thanks.
flatblack97
shoot, i've even used carb cleaner!
On paint???? i would not,thats a strong cleaner!flatblack97 said:shoot, i've even used carb cleaner!
Tom in Arizona
You might try a penetration oil, I use "Kroil". Also I found that if I apply hot air from a plastic welder it will loosen real old stickers so that they peel off easily. Then use the Kroil to dislove the adhesive.
dooman333
What wrong with usin' GooGone? That's what I used and it worked great. Seemed to be pretty gentle. Damages the finish?
When I took my old regisration stickers off, I just took some duct tape and dabbed the residue, took it off with just a few dabs
Product called Sticker Off.
brake cleaner works good for me. as long as the paint isnt from a bomb can it should work fine.
daman said:On paint???? i would not,thats a strong cleaner!
Yeah, I made the mistake of trying carb cleaner on a windshield. It destroyed the windshield. Actually melted the plastic.
OnDaTrail
I also just used goo-gone when I removed my rubber running boards. There was a lot of adhesive to remove and it worked great.
hereismylife
go to the auto parts store and get bumber staicker remover. It comes in a little spray can. Works good and not so destruction as other products are.
