throttle response problems
SaskViper
I have a 2002 viper and i am having problems with throttle response from an idle to full throttle the engine stalls. If you slowly acelerate there seems to be no problems. Does anyone have any suggestions on what may be causing the problems. If so please reply
have you checked your carbs to see that they are clean.that would be a good place to start
I had the same problem, but mine was with the T.O.R.S.. Throttle Overide sensor. I just unhooked mine and no more problems two seasons later. Only problem with the engine I ahave had. Hope this helps.
It sounds like the carbs, but it could be the tors but you can tell this when you give it gas as it will stutter step right away. If it's not doing that get your carbs cleaned
