Any tricks to this, or just take out the bolt and pull? Are there torque specs for the install?
Thanks,
Bob
Thanks,
Bob
98srx6
It should slide right off the shaft. Not sure on the torque specs, just tighten it with a ratchet w/ the parking break on and it should be fine.
Brad
- May 23, 2003
srx secondary torque spec is 46 foot pounds
yamaholic22
holy
that seems like a lot of torque. There is no way i go that tight with it.
that seems like a lot of torque. There is no way i go that tight with it.This site is great. Thanks guys.
I just get the bolt real snug with the parking brake on. I don't think I get to 46 ft/lbs either!
98srx6
I dont have a manual, so I am allowed to do stupid things.
I've seen the results of not having it tight enough and it is not good. Of course I don't have any idea of how tight that was because it was "just snug with a wrench" according to the unfortunate sledder. 46 ft/lbs is about half of what the average man can do with a normal size 1/2 inch ratchet.
98srx6
I use a 5 foot breaker bar, will I be okay?
S
srx_eh
Guest
...as long as you keep your feet on the ground!
ridesrx
what about primary?
I know you tork to 87ft.lbs and then back it off, and retork to what yet?
I think you torque the primary to around 88 ft/lbs and then back off, then retorque to about 43 ft/lbs...Somewhere within that vicinity will get ya close!
ridesrx
thanks
Brad
- May 23, 2003
Hay 98srx6 your a funny guy don't use the 5 foot bar just good and snug remember
Hey Brad, no need to get your panties in a knot...if the average guy can torque over 46 ft/lbs by just using the strength of his arms, I think everyone on here is fine. No need to go on the offensive...good for you, I for one am glad you have a manual that tells you all these things. Just chill, man...
FuzzButt
While I have not see the clutch leave the sled I have seen clutch parts, namly a broken off tower on an AC clutch, and the aftermath is not pretty. I think good enough is to much a guess.
Thanks to bringing the actual reading to our attention. I'll go and re-do mine as soon as I borrow back my torque wrench.
