Exciter Track Question
Dexter10
Maine
will a ripsaw 1.25" track fit in the 89 Exciter? I wondered if it will be too high. thanks!
installed a 136 x 1.5 track off of a summit on my 93 exciter, works great, have had no problems, this sled just won't die, 9000 miles and still going strong
93 Exciter II's could have different clearance in the front that the 89 had ? I know front heat exchanger protectors were a must when running studs on the 87-90 Exciters with stock .625"(?) tracks because of the tight clearance.
I had a 1" in my 89 and there was maybe another half inch clearance in the front, and I was using 8tooth drivers. Not sure what that would come out to with the stock 9 tooth drivers.
