chuckdogg39
Hey im not sure how to get the throttle cable off. This is the first time ive ever messed with anything like this. Any help? Thanks
Disconnect the cable from the carbs first and then you will have enough slack to remove it from the throttle block
chuckdogg39
how do i get it off the throttle block? I cant see how to get it out. I have it off the throttle now, but not the throttle block
did you remove the silver wire double hump thingy that holds the 2 cables in place? look closely at the far left side of the throttle block, below the kill switch, you will see it.
kirk700 srx
snowdad4 said:did you remove the silver wire double hump thingy that holds the 2 cables in place? look closely at the far left side of the throttle block, below the kill switch, you will see it.
Silver wire double hump thingy!
Man do I ever love this site!!!
Two Stroke Runs through my veins!
chuckdogg39
Thanks guys i got it off just fine...this handle bar riser project is a little more than i thought. When the rest of my parts get in im sure ill be back on here for info. Thanks
chuckdogg39
Now im running into another problem. How do i get the oil injector cable off? I see that it threads off but how do i get the cable off. Its tough to see down in there but it looks like its connected to another throttle body. How do i get all that stuff off? Is there something else i need to take off? Help! thanks
had i said cable retainer clip, would it have made you think of the double hump spring thingy?kirk700 srx said:Silver wire double hump thingy!Way to use mechanical terms!! LOL
