Todddob
New to clutching, I removed the plug on the bellypan and took out the large bolt on the primary. Should the two fixed sheaved slide off as one? It won't budge, any suggestions.
needaSRX said:I had to replace a clutch puller that I just bought, the tip of the puller started to kink and rub on my treads so took it back and the dealer lent me one that was much much stronger. The mechanic told me to clean the crank stub and the clutch end with emery cloth and the put some never sieze in there and it will be alot easier to come off the next time
Yeah,don't be puttin anything on the end of that crank,shine it up with emery and use a rag with brake cleaner to clean it and the inside of the clutch up but never grease it.Floader said:dunno as i would put anything on that taper, its designed to be a press fit. If if they dont come off, a little heat goes a long way.
linemech31 said:Easy with the heat crank seals arn an a hole to change if your just trying to do clutch work. torque the puller down and tap on the clutch with a dead blow hammer first. That may do the trick.
