j.e.1975
Viper Crank/Bearings
I have an 04 Viper ER. Pulled the motor to inspect and found the run out was out of spec. Split the cases and found the inner bearing on the pto side is shoot. Now for the question, the two outer pins are welded. Is this factory, warranty or just done after the fact. Motor is stock, I don't know if it had pipes at one time. Also is there anyone one here that can run a vin# to check the history.
j.e.1975
j.e.1975
