Bluthru
Looking for some input...just started this '02 SRX for the first time this fall...really tough to start...per usual needed to dump a bit of gas in each cylinder to get it to fire...have changed plugs...ran really rough, only PTO side firing. can hear spark arc from cap to plug when removing from center cylinder. Thing is, no arcing from cap to plug on mag side cylinder. I am pretty sure I've gotta bad case of phase separation (damn E10)! So I've pulled the carbs to clean, I am wondering if I have a bad coil? Would a bad stator cause loss of spark to only one cylinder? Anything else it could be?
Thanks in advance
FYI, I just installed Rocks' Yamaheater kit on my apex...Handgrips SIZZLE now!
Thanks in advance
