brosenberg69
Mountain Max Seat Riser Project - Pics added 11/18
So I did a bunch of reading here on TY and thinking about how to raise the seat of my 01 MM and I finally decided on a way to go. The project isn't complete but it is started so I figured I would start a thread about it to pass along some info and see if anyone had some suggestions for me. (my steering column is currently broken which is why the bars are laying the way they are - another project for this fall) I decided on having a peice of sheet metal fabricated that raises my seat 4". I know that in terms of weight this isn't he best way to go but I am willing to gain some weight to gain some comfort. I saw a lot of guys ramping their risers and I just didn't like that idea too much. I thought it would feel like you are sliding down torwards the tank. So here is what I had fabricated.
http://www.totallyamaha.net/forums/attachment.php?attachmentid=37031&stc=1
http://www.totallyamaha.net/forums/attachment.php?attachmentid=37032&stc=1
So it is basically a "C" channel made out of 22 gauge galvanized. I cut a peice of plywood to help strenghten the top and you can see a 2x4 at one end to help reduce the side to side movement. Not sure if I am going to keep it like this or come up with another way to strengthen it. I drilled holes in the botton of the channel that line up with the stock seat bolts and dropped the riser on my tunner.
http://www.totallyamaha.net/forums/attachment.php?attachmentid=37033&stc=1
I plan on using the space below the tunnel as storage if needed. The block of 2x4 on the left of this pic is only there temporarily to hold the peice of plywood up.
http://www.totallyamaha.net/forums/attachment.php?attachmentid=37034&stc=1
So with the seat raised as it is, it creates a gap between the seat and the tank. They way I am thinking of solving this is still in the expiramental phase but here is what I am thinking. I found someone selling a tank bag and what I an planning on doing is getting some padding to fill the gap and maybe sewing or velcro-ing the seat and the tank bag together. So here is what it would look like.
http://www.totallyamaha.net/forums/attachment.php?attachmentid=37035&stc=1
This does create the issue of figuring out a way to snap everything down but I think another small peice of galvanized riviet to the tunnel from the front of the gas tank back to overlap with the riser a little bit will work. I will rivet some snaps on that peice and lock it all down.
As I said, still working on it but I am making progress. What do you guys think? Any other ideas to throw in? FYI - the seat riser was fabricated for me for $60.
Any ideas are welcome!
Bruce
Bruce
