YAMMIEGOD3:16
DAN VERY NICE, BEEN DIEING TO TRY 8BU-10,s FOR YEARS. COOL STUFF!! 3:16 (yammie tony)
what are you guy's getting for speeds ?
jabber800
We ran between 115 and 119.5 mph in 2000 ft on different days.. Stock 700 srx with trail track and 96 carbide tipped trail studs.. Sled has run close to 126 in a longer run.. These are nbssr radar run speeds not Dream meter speeds.. Set up posted was used in ths sled.. Gearing was always a bit lower than speed as I found the clutches would pull a bit of overdrive.. Tried gearing taller but made no gains.. Sled chassis was totally blueprinted.. all shafts and drives aligned, Wheels and drive sprockets trued up etc etc..
extremelyfastmax4
i used the new drag&fly heelclickers last year in my 700redhead mountain max, ground the weights for 5000 engage ment and run 68 grams with black spring and 43/34 bender roller roster secondary white andblue spring thats used in the 800vmax4 @8700 for a short run u will not beat these weights but i think u guys are right about the top end speed from what i see is a little less. for the first 200 ft i was pulling on sleds that had 42 hp more than my sled but the hp run away near the end, but i was very pleased with the set up. blew away a lot of 800 polaris and some of the older doos but the new o9 800r doo was 2 much for the old girl lol
mopar1rules
yeah, those 800r's weigh nothing and have 150hp. they go pretty good.
