Carb heater bleeder
snow3
Central Pa
How do you get the antifreeze to bleed out of the carb heater switch? Does the sled have to be running, or at least warm? I can get fluid out of the rear bleed but not the front...
if you remove the top hose with the switch on it should push it out...., if you yank the carbs you dont need to bleed the carb heaters.....if you raise the rear of the sled it should force the air out the other bleed hole in the front.
