what's the easiest way to tell the difference between the to?
mountain_man
the srx skid will knock your teeth out in the moguls haha - srx has 9.5" rear shock travel, the shortest transfer rods out of all proaction skids, shorter limiter straps.
kirk700 srx
You got that right LOL but the viper aint the best dentist either !mountain_man said:the srx skid will knock your teeth out in the moguls haha - srx has 9.5" rear shock travel, the shortest transfer rods out of all proaction skids, shorter limiter straps.
kirk700 srx
Do you have two suspensions there? the viper has longer shocks front and back. I am not sure of the measurements but someone on here knows!
mountain_man
i have my origional srx center and rear shock here, the center shock is about 12 1/4" eyelet to eyelet, the rear shock is about 17 1/4" eyelet to eyelet...these are the aluminum body gas shocks, hope that helps...
Bingo! Thanks mountain man!!
mountain_man
no problem!
kirk700 srx
There ya go!! I knew someone would step up to the plate!mountain_man said:i have my origional srx center and rear shock here, the center shock is about 12 1/4" eyelet to eyelet, the rear shock is about 17 1/4" eyelet to eyelet...these are the aluminum body gas shocks, hope that helps...
