Anyone know if race logic is still in business I can´t get their website to work.
I wonder because I earlier had a srx 600 and ported it myself with templates from race logic and it worked very well. I don´t now how much power the porting made but the throttle response was incredible. That sled was stolen but now I have a srx 700 -01. And with 15000 miles on I think it´s time to check and maybe change the pistons. So with the cylinders off it´s a good time for some porting. I wonder if anyone know if race logic still exist or any porting tips/advice is wellcome. Any advice about case porting is also wellcome I wanna kill some more non blue sleds.
mopar1rules
i was wondering the same thing, as i was trying to call/get ahold of them for the last 2 months.....thru emails and phone calls. no one returns calls and answers back to emails. i think they may have gone under. too bad, cause their templates do work and are very user friendly. i was trying to get a set of v-max 4 templates.
In the past I did some resrearch in the tech section, I saw the porting map differences between the viper motors and the SRX, and the viper porting was said to be more aggressive than the SRX. So I guess that if you wanted to, you could update your ports to the viper specs and clean up the transfers while your at it...
Do you still have the race logic templates and instructions, if so the instructions should still work for your application as the theory is the same.
mopar1rules
neither of us are looking for viper porting templates. we're just wondering if race logic is still in business. FYI......race logic uses the same template for the srx and viper.
Race logic is located about 50 miles from me and I noticed on their website that it is under construction since March... It doesn't look good from this point, think they're gone, but hopefully not for good... I was only trying to help by making the suggestion of using the viper mapping.
well the only thing it make with this template you only raise the exhaust some so ...and cut the intake a little...ask bendersrx i think he got a set ..
mopar1rules
Sxr700Bandit said:Race logic is located about 50 miles from me and I noticed on their website that it is under construction since March... It doesn't look good from this point, think they're gone, but hopefully not for good... I was only trying to help by making the suggestion of using the viper mapping.
if you ever drive past there shop, wanna do us a favor and see if they are still in business for us.....thanks.
Sure! If I'm out that way...
