With the new (to me) kill switch installed the good Ovation fires up. It will run as the idle "calms" down from starting for a couple minutes but then dies out. If I'm really careful I can feather it back to life but most of the times it just dies. I cleaned the carbs when I put it all together but this is the first I've had much of any fuel through it. I can't recall what I have in for jets. I thought I went everything back to "stock" settings. Any suggestions? I've heard this 2 barrel single carb can be tough. When I give it gas, it really seams to want to take off.
