Pulled the track today to replace a ground down driver. Track looked beautiful when I bought it, and I looked it over as much I could to see if there was anything wrong. Well, when i pulled it today I found a 3" slice in the middle of the track
So anyways now that I have to replace it, I wanted to upgrade to a 1.25" Ripsaw or other brand as Ive heard Itll be a night and day difference in traction. Just wanted to ask the experts here if that lug size track will fit? Im planning on studding the track also, so will I need a protector on the front heat exchanger? Will I need to put in taller protectors then the factory ones on the tunnel? Different gearing? Im sure the clutching will need to be changed.
KneeDown said:Pulled the track today to replace a ground down driver. Track looked beautiful when I bought it, and I looked it over as much I could to see if there was anything wrong. Well, when i pulled it today I found a 3" slice in the middle of the trackSo anyways now that I have to replace it, I wanted to upgrade to a 1.25" Ripsaw or other brand as Ive heard Itll be a night and day difference in traction. Just wanted to ask the experts here if that lug size track will fit? Im planning on studding the track also, so will I need a protector on the front heat exchanger? Will I need to put in taller protectors then the factory ones on the tunnel? Different gearing? Im sure the clutching will need to be changed.
I suggest going with a 1.063" Camoplast Ice Attak. It's a 1" Hacksaw with 240 pre-molded lug studs. There's also a 1.25" Ice Ripper, it's a Ripsaw with the 240 lug studs.
You won't have to change the gearing.
WNYViper
The search option works great on here... Basically you would have to go to 8 tooth drivers in order to run studs on a 1.25 Ripsaw... other info: I have been told you can run up to a 1.75" track in an SRX without studs, I am running a 1.5 Ripsaw in my 98 SRX this winter...
http://www.totallyamaha.net/forums/showthread.php?t=30233&highlight=tallest+stud
