is this possible? or has anyone tried it
Triple X said:The hood will fit with the pipes but you have to cut a portion of the belly pan out just above the shock tower, and make a set of exhaust manifolds that fit between the cylinders and the pipes. It can be done but it is alot of work. It is probably easier to buy a set of Viper pipes in the classifieds. IMO. Do a search, this is a huge topic every year.
WNYViper said:Did you dent the pipes in to get the hood to close all the way? I have mind mocked up without denting the pipes and as low as they will sit and figure i will have to trim the 2nd vent opening to get my hood to close...
Triple X said:NO, I didn't have to dent the pipes, with the bellypan being cut the hood closed, it was a close fit and I had to use reflective heat tape, plus I didn't use the stock SRX silencer.
