madzx2
just got back from finishing up the chaincase. still gotta tighten the track and learn an easier way to install belts and set the twist in the secondary. i started her up and at first only one hole was firing but after a couple mins all three came to life. what a sweet sound (and smell)!!!!
kirk700 srx
We have 3 inches of snow on the ground and expecting 25 cm within the next couple days All the lakes are caught over and waiting for 30 below C to harden them up! C'mon Snow Already I wanna test out my new clutching!
i destudded a ripsaw for my sled going to put antiratchets on and switching tracks out.
Snowing right now and the SRX is in pieces
Not enough to ride on though, so i dont feel so bad.
Not enough to ride on though, so i dont feel so bad.kirk700 srx
I painted my trailing arms white with A can of tremclad! Then I tried to clearcoat the friggers with tremclad clearcoat and now All i got is spider webs everywhere! guess its time to sandblast and get a professional to do them right! Anyone know a trick to spray cans? I had the paint flawless but Fu@#n Clearcoat!
Nice SRX amatosrx I love the custom paint job with the flames and the bumper. I have my mtnmax600 ready just have to clean it up a little yet give it a waxing. The SSX I just got the hood back from the painters and hopefully by the weekend I may try to start it if everything goes good. But still have a fair amount of work to do on it to make it rideable but we should have time yet here in southwestern WI.
kirk700 srx said:I painted my trailing arms white with A can of tremclad! Then I tried to clearcoat the friggers with tremclad clearcoat and now All i got is spider webs everywhere! guess its time to sandblast and get a professional to do them right! Anyone know a trick to spray cans? I had the paint flawless but Fu@#n Clearcoat!
What temp were you at when you tried the clear coat?
Clear coat is kinda fussy, comes out best of you can have some type of booth to spray it in... also depends on what temp the activator is made for...
kirk700 srx
I was in my garage with my wood stove goin it was pretty hot in there ! its spray clearcoat from tremclad in aerosol can I have an auto body technician spraying them for me now!DV8 said:What temp were you at when you tried the clear coat?
03sxviper
My Sled is in pieces as well. waiting on a few more parts to show up, but as of right now its striped, no eingine, chain case, skid, drive shaft. etc
Mods that are installed or waiting are:
Bender tripple pipes
Bender head mod/with opti cool gasket
carbontech reeds
rear heat exchanger
machineing drive shaft rollers
bender light weight brake and hub
all new bearings for chaincase and driveshaft and jackshaft
Drop down top chain case gear
Bender adj engine torsion arm
Aeen performance clutch kit
Metric M-10 suspension
powder coating m10 rails and control arms, and pro action trailing arms
painting hood flat black
belly pan protector
Think it will go fast now? LOL
carbontech reeds
rear heat exchanger
belly pan protector
