Sled runs fine but, only getting it up to 90 mph. Anyone know what the problem could be because i think it should do more then that.
Thanks.
Thanks.
TopGunnSrx
Whats it revving out to? Also is it all stock?
i think about 8400 rpm and stock
tntmax
you gotta make sure your power valves are set right and your cables havent pulled through the end of your valve?? that is one thing that will effect some top end performance...
sweet i just ordered a new power valve cable and valve because, it was starting to pull through. How fast should a srx get up to?
Hope that takes care of that problem.
tntmax
i recommend you P.M. Turk with your sled setup, ex, jetting,clutching,track, and he will be able to tell you anything, Trust me
Check out your rear suspension. That is where you will loose most speed, weither being wore out bushings or bad bearings, along with maybe a bad shock.... Are limiter straps tight or any slack in them? Make sure you are running the correct belt..
8400 is where you should be. If your in real loose or deep snow thats all you will see for mph. On hardpack you should see 110ish unless your running a deep lug track or a ton of picks. I doubt you have a pulled thru cable if your hitting 8400 rpm.
I don,t think were getting the whole story here.
meat12
Track tension, worn belt, could be alot of things. To help the guys on here help you, tell more about your setup. Alterations from stock on all areas of the sled.
or he could be like me and weight 280 pounds. that effects it to
unclearpine
What are you running it on .Frost?Arruda said:Sled runs fine but, only getting it up to 90 mph. Anyone know what the problem could be because i think it should do more then that.
Thanks.
