1998 SRX 700 Jetting with bender cold air kit.
VmaX 600
Minot, ND 58701
Hey guys just trying to figure out what I should have for jetting.
Its a 98 SRX 700 with Bender Cold Air Kit. Also if anyone has some clutch setups please let me know.
yeah was only going to change pto, center and mag look good, on the safe side but with todays gas i'd rather run a little further from the ragged edge than in the past
VmaX 600 said:
What do you guys think of using a Tempa Flow?
i've heard far too many horror stories, to even want to try it. i'll never use one. didn't even want to try one out, even before i heard the horror stories.
patsxr700 said:
I have 145 all the way across,it runs great but whach out how cold it is... lol
what is your elevation, cause a trail srx won't live on that jetting here where i live. you would have to be in 30+ deg weather. 145 in a sx-r sounds right, but not in a srx.
VmaX 600 said:
Right now I have. 152.5 pto. 152.5 center and 153.8 mag. So no idea why so different.
your a little rich. pull the plugs and check out the piston wash. are there other mods done to the sled (besides cold air kit), to necessitate the need for the richer jetting?
You don't really think that thinner air is going to require more fuel do you?
Don't remember what I used last time out(have to consult the notebook), but when my sled was stock I ran 142.5 at home and 130's when we went out west. Drop the mains, drop the needles, raise the pilots when going from the flatlands to the hills.
Ride.Race.Live said:
ryan... the higher the elevation the thinner air is... but also sharper/ colder... the higher the elevation the higher the jets...
No, Ryan is right, higher the elevation the lower the jets.
