Hello Niko I Was Reading Your Post And Had A Similar Issue When I First Got My Used 02 Viper..... Check The Water Pumps Mechanical Seal Its A Weird Spring Loaded Set Up That Can Leak And Look Really Bad. I Replaced Mine The Job Is Not Too Bad Search The Forum You Will Find Detailed Posts On This. But Before You Do This Try Running It Up To Temp A Few Times On The Stand And Let It Cool Down Fully And Repeat.. The Reason I Say This Is The Following Season I Had The Same Leak And All I Had To Do Is Get The Motor Hot A Few Times And Good To Go For 3500 Miles Last Season.....
Good Luck Dont Lose Faith Either
Jdp
Jdp
