wifesviper
I just bought a 2002 viper with bender pipes.The pipes where put on when new and the person I bought it from had it set up by dealer and says it rock & rolls.It has a 1 1/4 predator track with 288 studs which I think is over kill.My question is he geard it down to 23/38 and put 8 tooth drivers and cut 2 teeth of the speedo gear.It is better to run stock gearing or leave the gears the way they are? Will the speedo be close to gps or way off as usual? He also has the bender clutching in it with the stock helix.He told me it worked best that way.Thanks for any help
