elevatorman718
Vmax tranfer rod spacer question
Hello all, I am new here but have been reading the posts for a few days now. My question is with the stock Transfer control rods is the mod to get more weight transfer to remove the top spacer? The Tech section is a little vague on this. Thanks for the help, Gary
elevatorman718
So, what this dosent warrant an answer?
The thinner the top spacers the more weight transfer you will get.
elevatorman718
Is it OK to use none? Will that be too much transfer? Thanks Turk
I would use the thin mountain max spacer.
ridesrx
I just replaced the factory ones with a 2.5mm one on my 2000 sx600r. I have only tried it on the grass so far, but it transfered way beter. Maybe too much. We'll see the first time I slam the thing into a corner and hit the gas. If I don't hit a tree, I guess I'm ok. I am going to bring along a couple of 5mm ones so I can snap them on in an emergency right on the trail. It will take some fine tuning to get it just right.
ekimsx600
A friend of mine pulled them out of his 01 srx and it was great going in a straight line. I didn't care for it coming out of the corners. With the power of the sled, and 192 picks, I couldn't keep the skis on the ground. If I were you I'd look for a set of adjustable rods so you can dial in what ever transfer you like.
elevatorman718
I would like to get a set of the adjustable rods, but I cant see throwing money into a sled I only plan to keep for this season. If I just do some of the inexpensive mods to it that are mostly just my time and labor, I can get a little more fun out of it and move on to a new sled. I mostly use it on the trails anyways and it is more than adequite as a trail machine, it just lacks the top end and ability to pull the skis that you would think a 700 triple should have. I need to work on clutching and traction issues.
