Changing crank seals
Concept Carbon
Ottawa, ON.
Im in the process of putting my case back together Im using yamabond 4 just wanted to ask if I should put some yamabond on the crank seals or just assemble with a bit of 2 smoke oil.
Thanks Jay
no need to put threebond on the crank seals. i just apply some grease to the seals. apply oil to the crank bearins, rod bearings, and the cavity where the oil pump/water pump gear is.
