helix
and the choices are...
1.add rivets to primary weights?
2.Secondary spring from 9/1 postion to maybe 6/1?
Turk said:Allways/allways 100% of the time with out fail tune rpm,s with the primary!!!!
in this case 300RPM over inner or outer hole for the rivet?Turk said:Allways/allways 100% of the time with out fail tune rpm,s with the primary!!!!
helix said:It's a 2004 600 SXVENOM ER
Primary.. spring YWYL,8BU weights empty.
Secondary Hauck Red spring in position 9-1 ,Hauck Helix "T"Dual angle.
Rev 85-8600RPM flat pull in the mid range want to be at 82-8300RPM
Hauck instructions:if RPM to High set sec at 6-3 or add 015 Rivets (what hole?). If to low set sec at 9-3 or may need lighter rivets.
helix said:thanks fellas. Does anyone know what the Hauk "T" Helix would be? You guys are worrying me with some things you said.Quoting Turk "8BU's are unheard of on 600 triples"
Side show Bob " 6-3 or 9-1 makes little sense on most Yamaha Helixs"
