Secondary question ( 98 700 Vmax )
Bluenote
Winnipeg / Canada
Ok I was just getting all my new toys on and making sure everything is greased, and tight, and noticed that my secondary had movement, now me coming from polaris to yammy I am unsure how much play it should have , if any. The play is if you grab the entire unit and pull it back and forth to the bolt if that makes sense, the guy who just had work done on it last fall said he replaced the secondary and clutch, which I can see was as the writing on it is not factory. Now I just went and tried to tighten it, and it is snug, I was not going to force it, but I saw he placed, and again this may be factory style, but thin washers between the bolt and secondary, and if I was to guess there is about two fingernail thickness of movement, so maybe one thin washer.
Should I be alarmed?
I know on my polaris you had to have it tight, and the only play you had was the entire shaft and secondary, not the secondary and bolt.
Thanks for the help.
