has anyone used one of those? whats your thoughts about em? are they reliable? what brand are you using?
780srxgeorge
money
i bought 99 700 srx in the fall of 02 or 03. with maximum per 780 ket. road HARD put away wet!gave him 3000. 1 rebuld & the rest was fram work.long travel front & back.aint never sell.looks like 02 know.BUT leave it stock with some cluctching & gear change nice little ROCKIT!
max performance went out of business about 4 years ago but you might be able to find a used 780.
A 780 mill will gain you about 20 HP on your 98 and you can use the stock pipes
You need the power valves, cylinders, heads, pistons, and rings
x2ryder
I had a Simons CPR 780 on my 2002 it rocked. I sold it and kick myself to this day for doing it.
Properly jetted they can be reliable as stock.
This will be year three on my 780. Running like a fine swiss watch. Good fuel, proper jetting, and proper warm up. I feel that given these three things it's as reliable as a stocker.
9801srx
x2!!!Ryan B said:This will be year three on my 780. Running like a fine swiss watch. Good fuel, proper jetting, and proper warm up. I feel that given these three things it's as reliable as a stocker.
sooo.... where do i buy one of these kits? homepage adress anyone?
it really feels like my sled needs to be cranked up to be able to put up a fight against my friends m7:s
bufalobob
where in sweden are you located?
bob
bob
bufalobob said:where in sweden are you located?
bob
um pretty much in the middle of it, in the AC County
why?
im not buying a BB kit here, prices on shit thats fun in sweden is very high, like a front shock to my snopro racer 600 cists about the same as a brick of gold
bufalobob
mike nordstrum raced for bender & would come over here for the summers to work/drag race. he has a performance sled shop in sweden & is very good @ what he does. races asphalt now in sweden w/ a yamaha. if you want i will post his address & #.
bob
bob
yeah that would be great!bufalobob said:mike nordstrum raced for bender & would come over here for the summers to work/drag race. he has a performance sled shop in sweden & is very good @ what he does. races asphalt now in sweden w/ a yamaha. if you want i will post his address & #.
bob
do you have the home page adress to some companies in the us that sells bb kits for the srx?
im thinking about importing the parts...
edit: i just found his homepage . mike nordstrum = micke nordström in swedish
www.mnracing.se
thanx for the tip
bufalobob
the bender 835 makes the most h.p. & is very dependable. mine was 194 h.p. @ dyno tech on pump gas. jim said if i leaned it out for the day it would be 200+. i have about 3000 trail miles on it & no problems. 7 mpg on our crappy wny trails & 9 mpg in canada. that's w/ reverse & viper suspension front & rear. tell "the swede" i said hi!
bob
bob
780srxgeorge
3 pipes
i don't know how cold it gets over ther.but a cold big bore is a serious 2 hander when cold. when warmed up hang ON!!
780srxgeorge said:i don't know how cold it gets over ther.but a cold big bore is a serious 2 hander when cold. when warmed up hang ON!!![]()
haha sweden isnt russia :P it gets about minus 10-30 degrees celsius in wintertime, so i wont need steroids to be able to pull the starting rope...
hmm, so whats the deal, should i get a bender or a hauck kit? dunno whats best and most bang for the bucks... is it possible to buy one of those kits used? like on ebay or something maybe??
valin
The rope won't be hard to pull.............
Try pulling over a 70mm stroker 1136cc triple with 185 lbs of compression, using a stock SX recoil....
You need one of those starters like the top fuel dragsters use. Just put it on the clutch and let it do the work.
780srxgeorge
yeah i had a brain fart on snow!!!!!!!. my sons stock low miles 98 700 feels like a bad clinder compare 2 my 780 when cold. i rebuild it about 5 or 6 yrs ago still purrs like
aaaaaaaaaaaaa kitty
