Simons cpr instructions
BIGJOEVIPER
Clio, MI
I bought a set of Simons CPR triple pipes for my viper. Anyone have a copy of the instruction sheet for proper installation.
what are you looking for. I dont have any instructions but i do have the jetting that was su by jeff. It was bought by me this way but i was told its right by the guys on here. I have a 04 viper s.
I bought the jet kit from him but he didn't send me insructions on which cylinder gets what jet and needle clip positions. also wanted to make sure I put heat tape in the proper areas.
Here is what im running. Im also running v force 3 reeds and heavy hitter clutch kit (I'm still learning about that). My jetting is as followed:
PTO side (clutch) Main 160, Pilot jet 47.5, Clip 4th ring both washers on top.
Center Main 160, Pilot 47.5, clip 4th ring both washers on top.
MAG ( exhaust side) Main 162.5, Pilot 50, Clip 4th ring both washers on bottom.
Not sure if thats what your running but this is what i have. I have a feeling it runs rich by the looks of the plugs but i will have to see. I'm going to start where im at and aee how it goes. I do a lot of river riding in low snow conditions so rich might not be a bad thing. Hope it helps
Thanks, this is what I was looking for! Finally talked to Jeff Simons and this is what he told me to do.
PTO and Center, Main 160, Pilot 50, Clip 4th - washer on top and bottom.
Mag, Main 162.5, Pilot 50, Clip 4th both washers on bottom.
Mixture screws 2.5 turns out.
Thanks for your response.
Joe
