Clutch Weights
JERSEYJOE
TUG HILL NY
OK I took the Viper clutch apart, The weights have grooves out near the tip so I need to replace them. Should I just go with the stock 8EK-00 or something elsre? Sled is stock but I am going to use the 50 /40 helix with green spring at 70 degrees.
Also if I used the stock weight shouls I change the rivet weights to some other setting?
why 50/40 helix w/8EK weights? i don't think you'll get the weights heavy enough and w/a green spring @ 70. you probably have to change the primary spring then, to get the rpms down, but only testing will tell for sure.
boy MAC, you're a generous dude. ;)! anything i can have for free from you, as long as you're handing out X-Mas presents.....LOL.
Sorry Mopar - Joe and I are Friends, practically neighbors, and best of all we ride together in NY and Quebec. Joe didn't know I had the weights since I purchased my viper new in 2003. I installed CPR pipes with Zero miles on the sled and never ran the stock weights. I have a lot of stuff a should sell on ebay and never make the time.
