heay exchanger vs studs
viper700t
NB
I am planning on installing a rear heat exchanger on my viper, however i have a studded track and everyone says i need heat exchanger protectors. However i can't seem to put my hands on some. What is my next move?
are they all the same..do they just rivet in front of the exchanger..and does yamaha still sell them r are they discontinued
ok, and if i can't find one i'll just fab one up because they look pretty simple to build. But i believe my dealer was going to get a viper mountain heat exchanger, however i like the srx ones. does the srx fit on a 03 viper and is it better than the viper mountain one.
I just put an SRX cooler in mine, not too much work, I had to do a little cutting, and drill the new hole for the bleed screw. I also found my tunnel protectors were too long for the cooler to fit in there all the way, so I had to grind those back a little bit. Once you are done, everything pretty much looks factory.
