alaskanrocket
Im not sure what the heck here. I just took her out for the maiden voyage after the motor swap. I used the head off the '05 but a motor from an '03. The speedo worked great for the first 12 miles than just read 0mph and the odometer just stayed the same. Any thoughts??? Thanks Jess
dirtjumper895
which ecu did you use? Also which guage cluster? Please provide more info on what electronics you are using.
alaskanrocket
The Only thing off the '03 I used is the motor (except the head, I swapped it with the '05 head) Besides that it's all stock '05 electronics.
dirtjumper895
I'd start with the speedo pickup, it is located below the secondary clutch. Make sure the wires are good. Test everything for continuity and there should be some sort of resistance value needed on that pickup....
Jess... check your PM mailbox. I have sent you messages regarding the rear hose cover and hoses off of your Mtn Viper. Jeremy
pipdviper
Ive seen the main shaft bearing go out and take out the pickup several times.
