kirk700 srx
Anyone know an easy way to remove rivets from weights? should I just grind them off?
valin
I drill mine out with a bit that is a bit wider than the hole in the weights. Then, once I get to the weight, I press them out.
mopar1rules
i just grind the head of the rivet off, and then tap out w/a punch and hammer.
kirk700 srx
I tried my sled again last night while it was a little colder and things seemed to be a little better, at first it reved at 8000. After the carbs adjusted to the cold it ran 8400. My jetting is stock with #1#2 146.3 #3 148.8 jetting. At 0 degrees the sled just doesn't seem to want to rev it out! but below -10 It wants to scream. So I am figuring I jumped the gun on having too much weight in my primary.Guess thats what I get for being impatient!
Thanks for the help guys This site rocks!!
