Rear Heat X-Changer Protector
Gagt518
Albany,NY
How are these installed? Do i need to take the stock seat off and unriviot the rear X-changer? Ideas?
Leave the HX in place, place the protector over the HX in line with the track windows, mark the holes, drill and rivet.
I would just remove the 2 rear suspension bolts and drop it down.That will give you room to use gun.The holes in protectors should line up with existing holes in exchanger and tunnel.Just drill those out and then install protectors with new rivets.
