I was told that the RX1 front shocks are a direct bolt on to the SRX's front end for long traveling it. Has anyone done this yet? anyone have any pictures of the change's? I am going to try and do mine over the holiday and just want to know what to expect and what to look for. Anything special I need to do to do this? I was told to just bolt them on and reallign the ski's for toe in. Thanks for any insight in advance. This site is still the best....
staggs65
you probably meant this but you want 0-15mm toe-out not toe in, toe in will cause darting, dont know about the shocks
staggs65 said:you probably meant this but you want 0-15mm toe-out not toe in, toe in will cause darting, dont know about the shocks
you are right, that is what I meant.
musselman
RX-1 shocks are 17.5 inches long, I would think that would be too long since viper shocks are 17" and stock SRX shocks are 13.75". RX-1 mountain shocks might work though, they are 15.5" long.
