Hey guys, Just picked up a 02 Viper this summer. Just went through the carbs to prep them for the season and cleaned the power valves. Everything went real smooth thanks to all the threads and power valve tech sections so thanks for that! Just had a question on reassembly, should I lube the valves with oil or anything when reinstalling? I assume I should put some oil on the seal the valves ride in but should the rest of the valve be dry or a light coat of 2 cycle? I didn't seem to see anything about that in all my searches.
Also my fuel screws were all about 2.25 turns out, and it seemed to run just fine through the yard and stuff so I put them back to that setting. From what I've read on here anything below 1 7/8 turns the vipers tend to get an idle hang so I'll leave them at that and try it out. Pilots and mains are stock sizes and I'm at about 800 feet above sea level. Thanks for all the good viper info on the site!
