02VIPER ER
I just a 3inch riser block with a pivot, a total of 6inches, on my 02 viper ER
and after installing my custome break hose and RSI throttle/Oiler cables
i found out my Handle bar wiring is too short,
I read that people with this issue are splicing/soldering in new wire to make the harness longer.
is there another way to extend the harness without cutting up my stock wires?
Like some sort of electrical harness extention with plugs on both ends?
I'd be happy if i could just get a pair of all the connectors and make my own extention harness
any suggestions would be appreciated
Thank for the help
Thank for the help
staggs65
maybe get the connectors from a salvage yard with the wire already on them to extend yours
1995vmax500le
i just extended all my connections a few weeks ago. i ran into the same problem. i just took my time and added 5" of wire to each existing connection. took a bit of time but it worked out good.
