sideshowBob said:I just reread jaydaniels results...the voltage reading prior to adjustment on his was way too high, the opposite of mine!!! I will go back + check my procedure again and report if its different. Our set voltage numbers are approx the same.
Sorry, I'm going form memory here but maybe it was .07. For some reason I was thinking it was higher not lower. Either way, I had to rotate mine almost fully counter clockwise to achieve the desired results.
