I am looking to remove the primary clutches on a et 340 & et 300 is the clutch tool the same? & are the clutches interchangable would the 340 clutch work on the 300? I have a bad rattle in the 300 clutch looks like a bad bushing that yamaha has on back order, anyone have the clutch tool I need?
Thanks Tony
Thanks Tony
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Yes......you can use the same tool, and you can interchange them.
Bruce
Bruce
Clutches
Thanks Bruce, Hows it going? Last time we spoke was about long traveling my SRX, I found another skid for it & droped it in, worked out good ! a friend of mine gave me a et 340 for parts, trying to address this clutch issue w/ my kids et300, the 340 clutch looks to be tight I will try to switch them soon as i could get a remover tool. Thanks Again & Have a Good Christmas ! Tony2ooosrx said:Yes......you can use the same tool, and you can interchange them.
Bruce
YAMMIEGOD3:16
TONY, ALL YA NEED IS PULLER FOR STOCK YAMAHA PRIMARY CLUTCH. THOSE CLUTCHES SHOULD BE THE SAME. 3:16 (yammie tony)
It has always helped me to grumble a bit on the real stubborn ones.
Puller
Ha Yammie Tony , I tried my clutch puller from my srx, no good the bolt thread is larger on the et clutches? need to get the puller for the et clutches, i will try dennis kirk.
Ha Ding, I should have your muffler pics today.
Thanks Tony
Thanks Tony
YAMMIEGOD3:16
ROTFLMAO!!! TONY, BET A PULLER FROM A SRX 440 WOULD WORk INSTEAD OF A PULLER FROM A SRX 700!!! lol. THIS FORUM IS THE VINTAGE FORUM lol. 3:16 (yammie tony)
