PhazerII72909
Hey guys,
My little 440 rocks, very fun to ride. But when trying to keep up with the bigger sleds, it lacks a bit. I don't have the cash to upgrade to something newer so I'll stick with the oldies for right now. What can I do to that little motor to make it run faster? Pipes? Carb? Etc.....
thanks
thanks
PhazerII72909
Just had an idea. What if I took at y-pipe from a phazer and swapped it with the y-pipe on the 440? I have a PSI pipe from a phazer. Would this work???
YAMMIEGOD3:16
WELL, ALL I WILL TELL YA IS ANY PIPE CHANGES YOU MAKE, KEEP A EYE ON YOUR JETTING. 3:16 (yammie tony)
PhazerII72909
Ok thanks. Where would I be able to find different jets for my carb?
heres an idea, getcha an intake system off a phazer too. carb boots, carbs and boost bottle. all should just bolt on. if you use the twin carbs and PSI phazer pipe you will need to update the carbs for mid range burn downs. all easy stuff. heck i got everything minus the boost bottle...
PhazerII72909
Not a bad idea. The thing is, I am clueless when it comes to messing with carbs. I have a phazer with a bad motor that I could swap everything. I tried the y-pipe swap and the phazer pipe was too wide for the exhaust ports.
yes, the phazer y-pipe has a funny mounting with the two inner bolts being right close together. what if you just tried swaping the pipe by itself. if it fit you would probably need a different clutch spring...
the carb swap should be pretty strait forward. although finding an air box to fit might be a different story. maby a couple of K&N's. keep an eye on your plugs for jetting. this i think would give you good top end with little clutch modifications (if any). if the boost bottle interferes with the cooling shrouds, and wont fit either way dont worry, carb boots from a SRX 600/700 should mount to the SS cylinders and eliminate the boost bottle....
PhazerII72909
Shaweet! I've tried the just the pipe it self and it won't fit. The y-pipe from the ss is at an angle and wouldn't fit. I have some clutch springs from a parts sled we have, but i can't tell the difference between them. And I don't have a clutch too to get the damn thing apart. I've heard of people who just gut out their airboxes, does this do anything performance wise? thanks for the feedback.
Sledsquatch
- Sep 29, 2008
- Carleton Place, Ontario
- www.simplifiedaudiovideo.com
tie your sled to the back bumper of the bigger sleds and you should keep up without a problem, minimal cost in rope or maybe you already have some kickin around in the garage.
I had a 82 SS 440 that had a comet clutch and it would run pretty well. Verry quick little sled.
PhazerII72909
Yeah I've heard of some ppl who have their 440s clutched. Do you remember what kind of comet clutch it was? 108 maybe?
Duster I think.
PhazerII72909
Anybody know how many times you turn the pilot screw out on the 440s?
