VmaX 600
Hey guys just found out on the SRX I bought and rebuilt has bored carbs. They were bored out to 35mm. Guess I was just wondering what should jetting be with bored carbs and bender cold air kit.
Also is there much of a performance gain with the bored carbs?
VmaX 600 said:Hey guys just found out on the SRX I bought and rebuilt has bored carbs. They were bored out to 35mm. Guess I was just wondering what should jetting be with bored carbs and bender cold air kit.
Are they straight bored or taper bored???
VmaX 600
straight
I would start out with 152.5's to be on the safe side. You can always go down if running rich. Check your plugs on wide open runs.
There is really no performance gain to speak of. Maybe just a few HP 2-3. You wont feel the difference vs stock carbs.
I would run the stock carbs if it were my sled
VmaX 600
tomseal6 said:I would start out with 152.5's to be on the safe side. You can always go down if running rich. Check your plugs on wide open runs.
Thats crazy why even mess with them if thats all you get?
staggs65
is it stock porting, the bored carbs make more difference on a ported motorThats crazy why even mess with them if thats all you get?
9801srx
one mod don't usually get you a huge gain,it's all the little things together in the right combination that make big power.VmaX 600 said:Thats crazy why even mess with them if thats all you get?
harness racer
if you d'ont like them ill trade ya for stock ones
vince
vince
VmaX 600
Nope the porting is stock. Does not mean that it didnt have ported cylinders at one time. I already have a set of stock ones one the way going to give these a try first.
Now theres a thinking manVmaX 600 said:Thats crazy why even mess with them if thats all you get?
