I have an 02 Viper with about 4500 miles and am looking to change the track. I would like to get something a bit more aggressive than the OEM. The only changes I have make is to add the rear exchanger and protector. I was looking at one of the camoplast tracks with 1.25 inch lugs but wasnt sure if I would run into any problems..Has anyone done this that might lend me some help? It would be appreciated...
bucky
I would suggest a 1 inch lug or .92 with 144 studs in the middle.
sx600
- Aug 10, 2004
There are a lot of posts on here about putting on the 1 1/4" track. I just put the ripsaw on my viper. Basically you have to either cut down some of the lugs that will rub - or do as I did and remove the front heat exchanger protectors and tunnel protectors. Not very hard at all to do. Just be carefull on the front protectors - they are welded on. Take your time and carefully cut through the welds and tap out with a hammer.
1.25 sneaker...
i had a 1.25 camo connected cone design no studs, loved it...
am in the process of removing it for a 1.25x136 ripsaw conversion, you have to remove tunnel/heat exchanger protectors to fit.... or you can change driver to 8 tooth and change gears to run studs, leaving protectors in..
I have been thinking about buying the kit #3 from mountain performance and going to the 136. The impression I get from the website is that it is a fairly straight foreward do it yourself project. Is this what you are using?
RedlineViper
i went with a 1" with 144 1.080's up the center... works great, and comes off the line like an animal now!
Canuck
Im using the 136 option 2
so far so good, i have a buddy with an auto garage, we have it almost ready to put back in, i have to get a couple bearings tommorrow from yami and some new slides, easier to change now that it isout... kit is straight forward, just be sure to read the directions completely, a few steps are slightly misleading... and the instructions have option 1, 2, and 3 all on the same papers... easy to get confused on kits with diagrams and instructions...
Brunter Burner
ONLYBLUESXV, Did you end up switching drivers, or did you leave the 9Tooths in it?
..SNAKEBIT..
went with a 136 x 1-1/2 ( had stock track with 168 studs )
LOVE IT will never yea I said never have a 121 track again
just install CPR pipes, like I seen on here some where?
ALL ROOST NO BOOST!
ALL ROOST NO BOOST!
