YamahaSXR700
hey guys, my bro has a yamaha srx 700, he bought it for cheap and the guy said he had rebuilt the engine in it, and um it looks like it has low compression, so we thorn the top end appart to inspect the piston and rings, and when we got the power valves out the mag side one was jammed in it, , and i forgot to mention that the guy before my bro, he did rebuilt it, because its not stock srx piston they are teflon coating on it on the skirts, and it looks pretty new, you see the cylinder has been owned, and could that power valve jammed up be a problem with the compression, we did a compression test i think it was 110 or less i cant remember, um and when u crank it to start it u see the diff of compression with antoher srx we had in the garage, any ideas
