New Track for a 99vmax700sx
Noid93
Arkansaw WI
i have a NEW camoplast hacksaw track(121x15x1) predrilled and plan on putting studs in. Drilled for 144 but probally put in 120. thinking about 1.25 accord studs. just a hot trail machine. tell me if i'm off base here. please recommend brand, # of studs, lenth, and most importantly, WHAT DO I NEED TO MAKE SURE I HAVE THE PROPER CLEARANCES FOR MY STUDS AND TRACK. What tunnel and cooler protectors ETC. I want to retrack this thing and ride the hell out of it without problems. thanks for all the help guys :bling:
I have same track on my SXR, You really need at minumum 144 but you might rethink the length. I have 1.125 and using alum backers. I ran a V formation in the center and every other lug on the outside. Ran over 2k last year had one broken stud, no pull throughs, Stud manufactured replaced broken stud plus 4 extra. You will need heat exchanger protector for front. I also run extra boggy wheels for marginal snow. The track hooks up great and alot of fun Al
i got front used srx protectors ...brand new rears ...and tunnel protectors ..pm me and let me know what you need
IS there enought clearance for 1.25 studs? I dont need any longer studs than that but absolutley do not want any troubles with hitting coolers and such.
THANKS
